configure flowmon key ipv4
key_name
ipv4
Description
Configures a Flow Monitor key with IPv4 parameters.
Syntax Description
key
Specifies the Flow Monitor key. |
| key_name |
Specifies the name of the key being configured with
parameters. Range is 32 characters. |
Usage Guidelines
Optional configuration parameters include the following:
- src-ipv4-addr is a source IPv4 subnetwork address given in
dotted decimal notation format.
- src-ipv4-mask is a source IPv4 subnetwork mask value given in
- dst-ipv4-addr is a destination IPv4 subnetwork address given
in dotted decimal notation format.
- dst-ipv4-mask is a destination IPv4 subnetwork mask value
given in dotted decimal notation format.
- port_no is either a source or destination TCP or UDP port
number.
- protocol is the protocol field value carried in IPv4
packets.
- next_header is the protocol field value carried in IPv6
packets.
- port-list is a list of ports given in standard CLI format,
fore example, 1:1-48, 3:5, and 4:6 represent ports 1 through 48 on slot 1, port
5 on slot 3, and port 6 on slot 4, respectively. Flows otherwise matching the
key received on any other port will not generate a group assignment. If
all (the default value) is specified or the
port-list option is omitted, then the key will be
installed on all available user ports that support Flow Monitor, including on
any new hardware inserted into the stack.
- key_name_other is used with either the
before or after keyword. It specifies
the name of a different key from the one being configured.
before implies that the configuring key will be higher
priority than the other key, and after indicates that the
other key will be higher priority than the one being configured. The insertion
is immediately before or after the other key regardless of other keys that have
been configured.
If a specific port list indicates a slot where Flow Monitor is not supported, the
command will be rejected.
The following command creates a key named 'k1' with no additional IPv4
parameters:
# configure flowmon key k1 ipv4'
This command was first available in ExtremeXOS 32.2.
Platform Availability
This command is available on ExtremeSwitching 5420, 5520, and 5720 series switches.
